hey everyone, i just bought a englander pellet stove the one rated for 2,200 sq ft. I like the stove it works well, but i noticed the glass does not stay clean, and also when the stove is running at a good clip with the feed rate on high the stove will vibrate and you can see the flame flicker and get smaller, im new to a pellet stove i had a Nashua woodstove before and burned about 9 cord a winter. now the way the stove is set up is like how the wood stove was, it goes from the 3" pipe to a 8" pipe then into the 11" x 11" flue. i opened the clean out door while the pellet stove was running and its was drafting quite a bit. i think its pulling to hard on the pellet stove and all my heat is going out the chimney. just need some input thanks!
