Castleton Stove installation question
Laura C
2
Pickens SC
Is the stove supposed to rest on the screws and not the stove feet? That is how the person who installed my Castleton stove left it.
  • [Hearth.com] Castleton Stove installation question
He might have done this to fit the stove to the stovepipe better?? Is the hearth out of level or are all the screws extended equally? Is there an extendable stove pipe section in the connector?
My installer did this too! We noticed at the end, and he claimed that's how it came from the factory. He used fixed length vertical pipe so we were stuck with it.
Same installer did a generally sloppy and not-to-code job everywhere else. We had a different installer basically rebuild everything, including lowering the legs. They couldn't get it all the way, but it came out much better.
The hearth is level and all of the screws are extended equally.
In that case I would have removed the screws or at least had them screwed in to the lowest setting.
I'm pretty sure they are for leveling the stove. Yeah I would have rather had them screwed in a little more but it doesn't really bother me.
They are for levelling however you don't extend them unless you have to. It is possible that each one could be extended differently but there should only be a small difference and they should be tucked up as much as possible.
Yeah my installer did the same. I didn't notice it until they were gone and had set the length of the double wall pipe. Not really a big deal.
