Catalytic Combustor Temperature
jaykay
27
Virginia
How do I measure the temperature of my combustor on my Englander 24 ACD? Where would I even put the probe in? Where can I buy one?
Side note: I found a little hole area behind the heat shields which is sorta near the combustor but not sure if that comes off or what… tried to mark it with the arrow.
[Hearth.com] Catalytic Combustor Temperature
From the manual:
There is a ¼” diameter hole located on the left side near the rear of the unit which is covered with a ¼” plug; the plug can be removed and a catalytic probe thermometer (Part #AC-13) inserted through this hole, which will monitor the operating temperature of the combustor. We recommend the use of the Condor probe thermometer .
Reactions: jaykay
From the manual:
That’s about the dimension of that hole within the heat shield. It’s on the left side of the unit. That must be it. Do I leave that plug out or do I take the plug out and just check it before activating and then plug it back up
Leave the plug in until ready to install the recommended catalyst thermometer. The thermometer will then plug the hole. The Englander part # is AC-13.
Reactions: jaykay
