- Jan 25, 2013
- 96
Hello All,
thanks for the help in identifying my stove model, it is indeed a Lopi flex. looks like an FX/SX? according to the manual. i have 35' on chimney, brick, and the stove is thimbled in on the main level (chimney goes to basement) about 25' from stove to top of chimney. everything was cleaned well before the season.
so this is my first cat stove and it came installed in the house. i have done some research before starting the season but i just want to talk to someone who runs one to make sure i'm doing everything right.
my current practices are as follows:
i always leave it in bi-pass mode until its hot and burning good, then engage the cat and start lowering the air as it stabilizes. typically burn at about 1/4 air or less.
flames appear strong but lazy with mostly secondaries.
i can look up through the door and see the cat is at least partially glowing while its burning, stops glowing when the flames die out.
there appears to be no smoke after the initial fire, however i can smell it outside and i notice it smells different then a normal wood stove burning, is this normal for cat stoves?
how do i know if the cat is running properly? it has a cat thermometer but it appears to not be working.
stovetop is really hot with cat engaged( i need to get an IR thermo to check it) and stove pipe is pretty warm, like lick your finger and get a sharp sizzle. (wouldn't dare try that on the stove top).
are there any important facts or tips or things i should know about running this stove?
just looking for someone to give me so tips.
thanks.
thanks.
![[Hearth.com] Catalytic stove assistance [Hearth.com] Catalytic stove assistance](https://www.hearth.com/talk/data/attachments/91/91155-f0b6434913c60a3b22ea810dedac3b28.jpg?hash=CMKOnTNeeX)
![[Hearth.com] Catalytic stove assistance [Hearth.com] Catalytic stove assistance](https://www.hearth.com/talk/data/attachments/91/91156-8143b04f908c564644ff242b3cc23e57.jpg?hash=4N6aJnmQSQ)
![[Hearth.com] Catalytic stove assistance [Hearth.com] Catalytic stove assistance](https://www.hearth.com/talk/data/attachments/91/91157-177e82b4e5a004be11d294306551345c.jpg?hash=f7CBnvHt-e)
![[Hearth.com] Catalytic stove assistance [Hearth.com] Catalytic stove assistance](https://www.hearth.com/talk/data/attachments/91/91158-339a5a12c9479c99e7c55328e5af5912.jpg?hash=OmA_e1l3GG)
