I got my new 543xp last week and I’ve been using it to buck up the truckload of oak I have here. I like the saw a lot and I’m surprised how well it’s done for a small light saw running full chisel chain on it but it’s got me stumped on something that’s happening usually (always) when I have a minor pinch while cutting the logs, and it doesn’t have to be a bad pinch, just the shift of the log before it drops off the the pole will make the chain bind up when I go to cut the next buck...and the brake hasn’t been set and the chain tension is fine. It’s like the brake binder has partially set or something? I always can get the chain to roll again by pushing the bad into the log poles while holding the throttle wide open for a second and then the saw cuts like normal. The Oiler is working good also. Any ideas? I’ve never had this phenomenon on my other pro saw before.
PS- I have stopped the saw and closely looked at the chain and bar all the way around and on the sprocket while it bonded up but I see nothing unusual to explain this. I’m on my 6th tank with the saw now. Maybe it’ll clear up after the break in period...?
