zapny said:Smokin or Thistle, how often do you mill over nine feet in one run.
zap
smokinjay said:zapny said:Smokin or Thistle, how often do you mill over nine feet in one run.
zap
As often as I can! Just move your guide down the log about 3/4 of the way....Easy Peazy!
zapny said:smokinjay said:zapny said:Smokin or Thistle, how often do you mill over nine feet in one run.
zap
I never did ask when ordering the ez rails (9ft) do they come in three foot sections?
zap
zapny said:Smokin, do you just rub the Bees Wax on the ends right out of the can?
Zap
smokinjay said:zapny said:Smokin, do you just rub the Bees Wax on the ends right out of the can?
Zap
I just paint the cheaper woods. Black walnut I use the bee-wax on the top and bottom and paraffin wax on the ends.
So your framing wood or softwood just paint the ends, hardwoods you may want to go the extra mile for.
I have a good recipe for making an awesome bee-wax blend that works very well and much cheaper!
zapny said:smokinjay said:zapny said:Smokin, do you just rub the Bees Wax on the ends right out of the can?
Zap
So on the pine I can leave the top and bottom alone then paint the ends(what type of paint?)
zap
zapny said:Smokin, looks like everything came in from what I can see, I might start putting it together tonight.
The ez rails (wet) are in the first picture (they had put them outside because I was coming and it started pouring just before I got there) then the second picture is the mill.
zap
smokinjay said:zapny said:Smokin, looks like everything came in from what I can see, I might start putting it together tonight.
zap
Yep yep...Grap a 1/2 wrench and lap-top set at kitchen table about 30 min's your done...Pretty cool video....
zapny said:smokinjay said:zapny said:Smokin, looks like everything came in from what I can see, I might start putting it together tonight.
zap
Smokin the white plastic piece is not in the package, how important is it.
zap
I went through the same thing even called them out on it......Turns out its just comes on the SMALL MILL ONLY
!! I email back and fourth as well, but it is not a part of your mill. Glad you caught that to! :lol: You are very educated on the mills for sure!smokinjay said:zapny said:smokinjay said:zapny said:Smokin, looks like everything came in from what I can see, I might start putting it together tonight.
LOL Funny stuff thereI went through the same thing even called them out on it......Turns out its just comes on the SMALL MILL ONLY
Just watched your video of milling and noticed you didn't have one so I figured it was for the smaller ones, thanks.
zap
zapny said:smokinjay said:zapny said:smokinjay said:zapny said:Smokin, looks like everything came in from what I can see, I might start putting it together tonight.
zap
It make me nuts for a week figuring I had a part missing.....Wasnt affarid of running it just wanted everything to be there....One comes on the mini mill as well it last about a full run...lol
smokinjay said:zapny said:smokinjay said:zapny said:smokinjay said:zapny" date="1309399841 said:Smokin, looks like everything came in from what I can see, I might start putting it together tonight.
Smokin one question before I start, about one minute into the second video about putting the mill together he says the bar is flush with the outside, is that the including the black cap?
zap
zap
zapny said:smokinjay said:zapny said:smokinjay said:zapny said:smokinjay" date="1309400084 said:zapny" date="1309399841 said:Smokin, looks like everything came in from what I can see, I might start putting it together tonight.
zap
Yes
zap
smokinjay said:Yes :cheese:
zapny said:smokinjay said:Yes :cheese:
Smokin, how far down did you tighten down the handle from the guide end?
zap
zapny said:Smokin/Thistle, I see on Granbergs site they say you can lose between 2-4 inches on how wide you can cut, how much do you lose or will I lose with the 36 inch bar.
zap
zap
Thistle said:zapny said:Smokin/Thistle, I see on Granbergs site they say you can lose between 2-4 inches on how wide you can cut, how much do you lose or will I lose with the 36 inch bar.
zap
With the 36" Bar I can mill logs up to 32".
