Check your Damp Rid!!!
mithesaint
512
NW Ohio
It's been really really rainy and humid here lately, and I noticed a bit of rust starting in my stove. I have the outside sealed up with duct tape, and did my year end cleaning about a month ago. I thought maybe it was time to check the Damp Rid and see what was wrong.
Oh my. There was water in the bottom of the Damp rid container. Literally a few ounces of water. Whoopsie. That explains the rust. Guess I need to check for holes in my duct tape job outside.
How does every one else seal up their exhaust and OAK? Pull the stove away and plug from the inside?
If it gets that bad that you have to check the Damp Rid , you got a more serious humidity problem to deal with .
crack the stove door or dramatically loosen it, if you get rust after doing that youve got your house in a swamp. Gotta plug the exhaust and OAK though if your doing that. I plug my exhaust from the outside and stuff a rag in it. I plug the OAK on the inside.
Hello
The Humidity here is the worst it has ever been in years! I just painted a firebox in a stove in the garage and a few days later is rusting! The garage is a walkout garage under the house and no dampness or mildew. However with 73 % humidity outside it is horrible!
Tell me about it. It won't stop raining. My garden is underwater, and the broccoli, lettuce, green beans, watermelon, cauliflower, tomatoes, peppers, and pumpkins are all making very real threats of dying. My sweet corn, cucumbers, and zucchini are the only things that look remotely happy. Annnnnnd there is another storm on the way in a few hours, potentially with an inch of rain.
Currently it's 91, with a heat index of 108 thanks to the 70% humidity. Might as well move to Florida with this nonsense.
Use a de-humidifier. My stove room hovers in the 70s % humidity and slabs of rust will fall from the inside of my stove without the de-humidifier. I now keep it below 65% and no rust.
My finished basement humidity stays at 60 rh with the dehumidifer running and after 45 yrs of summers, there are no signs of rust or mildew on anything. I think anything above 65 rh is about the highest you can go without experiencing dampness issues .
Thats about the range i see. Iv had my DH set at 60 and Zero rust. I just bumped it up to 65, so ill monitor it to see if thats too high.
Here in tropical RI we had a recent sunny day of temps in the low to mid 80's with humidity at 94%! It doesn't even seem possible! While on vacation last week in similar conditions I did a couple of 45 mile bike rides and stacked two cords. Can you say holy electrolyte imbalance batman?
I have one running in the basement and the central AC is on. I must have a hidden hole in my duct tape job, because the humidity inside is under control.
The Damp rid is designed to catch the water. That's its job.
Leave it in there. Mine will accumulate a inch or 2 of water over the Summer. One in the hopper, one in the ash pan. Good to go.
I use about 25 grocery plastic bags, bunch 24 bags, up inside 1 bag and stuff the exhaust. Then a few less for the OAK. I have taped in years past, but I skipped it last year and this year
After 5 seasons I am getting lazy, I used to clean once a day! Then once a week!, now I'm lucky to get to it once a month! Quad got 3 cleanings this yr and one of those was the end of year cleaning ;)
I've had good results using a Goldenrod dehumidifier http://www.goldenroddehumidifiers.com/introduction.htm. It's just a small cylinder with an electrical cord. I've used these in my gun safes for years with excellent results. They set up a convection current of warm air that keeps the humidity quite low. The only "catch" is you will have to leave the stove door cracked a bit to run the electrical cord out of the stove to an outlet.(I use a bungee cord to keep the door closed, then fill in the gaps with foam strips). I have had one running 24/7/365 for ten years in my safe without an issue, you can touch them while they are running, and they are UL listed. Of course I seal up my exhaust and OAK when using this setup. Just be sure to place it on the lowest level of your stove as you want the warm air to rise. Here on Long Island, humidity can be a real problem. I have had good results.
I've had good results using a Goldenrod dehumidifier h.
I checked out their website and they dont mention stoves or furnaces. I may just stick with my DH as it does my whole basement.Once i got mold on the bottom half of an expensive wood roll top desk as well as my stove getting rusty i knew i had too much moisture in the air.
The damp rid takes the moisture out of the air and deposits it in the bottom of the cup, much like a dehumidifier takes moisture out of the air and puts it in the tank....
Reactions: DexterDay and pen
IT dont cost that much to run the DH and its only for about 4 months in the summer. And it does the whole 1000Sf Below grade finished basement.
I learn something new every day.
Why do they sell refills then? I'm confused. I think I need another beer.
Reactions: smoke show
The calcium chloride (crystals) that you put in the top of the damp rid container absorbs the moisture and then drips down into the bottom of the bucket. Drain the water off the bottom as necessary and add more of the "crystals" to the top as necessary.
Who has a 4 month summer? Unheard of up here.
So sad, but true. July and August, then it is all over! So far this "summer" it is all rain. I might have been better off planting rice.
I have a dehumidifier in my unfinished basement. I keep it at 40%. The recommendation for finished or unfinished basements is at or below 50%. It runs 24x7 (turns on/off as needed). No issues, it drains into my floor drain and out to daylight.
