Chimney adaptor ring?
Chuckc
4
Ny
Hi just bought a cheap stove for my shop .Its a Mao Shing enterprises 602 heat box .I found out they been sued out of business years ago problem is i need a part I think.There are two chimney openings. there is a cast iron plate that locks in with two ears to block off the hole not in use. Im assuming there is some type of pipe adaptor that goes in the hole in use which is not with the stove does anyone know where I could possibly find one thanks.
Do you know what the diameter of the opening is?
Thanks il see if that will work but the mut stove has two cuts were two ears lock in but i may be able to make that work
That is the 5" to 6" adapter which you will probably need, but the part that mounts on the stove is called the flue spigot. Woodmans sells this for the actual F602. Give them a call for dimensions between the mounting ears, etc.
(broken link removed)
