New to wood stove ownership. Installed in March of '22. Started using the stove in mid October. Followed manual to the letter. Read that manual 50 times! After reading through these forums realizing there is a whole bunch not in the manual!! Thanks for the info all!!
To the point, last night started small kindling fire as per usual. Temp was just hitting 300 degrees on top. Flames were just lapping the bypass flu, then woosh. Heard it almost immediately! Wife called 911 as I closed the bypass flu and shut the air control to off. Lucky for us it is a double wall insulated pipe and no attic. Also the fire department is 4 blocks away! They arrived just as the fire was getting scary. Flames and sparks were shooting out the top of the pipe. Got so hot that the paint starting smoking on the outside of the pipe a feet above the stove inside our house. After the fire burned itself out, they doused the kindling inside my stove and aired the house out for me. Only damage was some discolored black paint on the pipe and a warped top cap. Scared the wits out of me though!
So I know now after reading through these forums I should have cleaned the pipe much much sooner! I am guessing I burned through almost 2 cords of wood so far. Mostly doug fir, oak and ash. Wood was seasoned, stored for 2-3 years in a shed. The Fire Captain said the wood looked great. Just should have paid attention to the stove pipe.
The captain told me that right where the stove pipe makes a 45 degree bend, 4 feet above my stove, is where creosote likes to build up, the smoke cools just enough to liquify. As the pipe warms up the creosote runs down the pipe a little until it builds up on top of the stove collar.
Also I don't think I am running the stove hot enough to prevent creosote buildup. I have been running the stove around 350-450 degrees on average. I have done the overnight burn quite a bit with the temps hovering around 350-300 as per the top thermometer. With air regulator half way and bypass engaged. I do not have a catalytic combustor. Am I just not running this stove hot enough?
![[Hearth.com] Chimney fire in 5 months of using our new VC Dauntless.... [Hearth.com] Chimney fire in 5 months of using our new VC Dauntless....](https://www.hearth.com/talk/data/attachments/309/309369-7f1081b4ed87639eecbcdf8c4c7837fa.jpg?hash=dv_JBXUMow)
![[Hearth.com] Chimney fire in 5 months of using our new VC Dauntless.... [Hearth.com] Chimney fire in 5 months of using our new VC Dauntless....](https://www.hearth.com/talk/data/attachments/309/309435-bfcfb26a7519f002250b3d10fc81836e.jpg?hash=8WD4emKbOg)
![[Hearth.com] Chimney fire in 5 months of using our new VC Dauntless.... [Hearth.com] Chimney fire in 5 months of using our new VC Dauntless....](https://www.hearth.com/talk/data/attachments/309/309436-b3f4f7ae9ec7bfa4073ba6bf89d607d5.jpg?hash=MEBZY3o603)
