Do most chimney fires start at the top or bottom? I have always thought the bottom because it should be hotter there but the few experiences that I have had appear to have been the top.
Almost always the bottom that is where the fire is that lights it off. There are some rare occasions where an ember can get pulled up into the chimney and ignite creosote at the top but it is uncommon.Do most chimney fires start at the top or bottom? I have always thought the bottom because it should be hotter there but the few experiences that I have had appear to have been the top.
Shut the air off and call the fire dept. A fire extinguisher can do it but you still want the fire dept there to check for hot spots.So what do you do if you have a chimney fire. Fire extinguisher. What are the options. How do you battle it
I have had 5 or 6 chimney fires over 30 yr span.
What makes you think it was not burning above the ceiling? if it was burning for 30 to 45 mins that is a pretty major chimney fire. Have you had the whole system inspected?but I probably would have if had gone above the ceiling.
What pipe is it that only requires 1" of clearance? Almost everything requires 2"I had triple wall pipe above the ceiling with 1" clearance above
the ceiling and could touch it with my hand but it was very hot.
If the pipe was glowing it was still burning pretty hard and still absolutely had enough heat to damage the chimney. Have you had the system inspected fully? I am still looking but have not found any old preway chimney systems that were rated for wood stove useage and only required 1" it may be there but I cant find it yet. I have found a few that were made for use with fireplaces that only needed 1' thoughIt was not roaring once I turned the air off, it was just smoldering and you could hear it in the pipe and see the hot spots
in the places where it was glowing.
Preway was for a fireplace originally. I have inspected the upper pipe too from the ceiling and from the roof, it looks fine.If the pipe was glowing it was still burning pretty hard and still absolutely had enough heat to damage the chimney. Have you had the system inspected fully? I am still looking but have not found any old preway chimney systems that were rated for wood stove useage and only required 1" it may be there but I cant find it yet. I have found a few that were made for use with fireplaces that only needed 1' though
Then it was never designed to handle the temperatures you have submitted it to. You really are asking for a disaster. Every time that chimney heats up you are lowering the ignition point of the surrounding wood. And the fact that the chimney is only rated to contain half the temperature that a chimney fire can produce is extremely dangerous. Do what you will with this info but you are really really gambling on a setup that is potentially very dangerous.Preway was for a fireplace originally.
Well I am glad you will be switching to pellets soon much less chance of disaster.Thanks for your concern, it has been running with a wood stove for 40 years now and under normal operation the outside wall of the pipe barely gets warm and the only place there is wood close to it (pipe) is where the support box is and that gives a 4th layer of protection.
So I think its safe. I am currently switching to a pellet stove so it should run a cooler from now on.
Do you know what the typical flue temps of fireplace vs wood stove vs pellet stove?Well I am glad you will be switching to pellets soon much less chance of disaster.
You do realize that I have heard the I have been doing it that way for 40 years many many times when we do fire damage evaluations for insurance right. The longer it goes the lower the ignition point gets. I am not looking to convince you I just want to make it very very clear to anyone else reading this that completely ignoring the very real and very clear dangers involved is asking for trouble.
typical flue temps will vary greatly based upon the appliance being used so not there is no way to answer that. But a chimney fire can easily run at a little over 2000 degrees in an open fireplace while the fire is still burning at that level the temps are knocked down allot by the huge amounts of dilution air which is why chimney made for prefab fireplaces don't need to be rated for as high of temps fire place chimney fires also tend to burn out much quicker meaning less time for heat to be transferred. Pellet stoves are completely different chimney fires while still possible are extremely rare with them. And if you are running a pellet stove through that old chimney you should run pellet vent up through it anyway so your clearances will be no issue at all.Do you know what the typical flue temps of fireplace vs wood stove vs pellet stove?
Generally when I get the 40 year thing from someone it is not worth my effort to try to convince them. I have been at peoples houses to inspect after a chimney fire caused a structure fire and still had guys arguing with me that the chimney was perfectly fine the way it is.What's wrong with Oregun that you don't care to convince him?
Yeah, I wonder how he's getting the chimney so gunked up with a cat stove? Wet wood, or what? Has this been with one cat stove, or many? How often do you sweep?What is the current stove on the chimney?
shut the air down and call the fire dept as I said before. Yes you can empty a fire extinguisher into the stove but you should still call the fire dept. They also make the flares that are supposed to put out chimney fires but they are marginally effective.Ok.. so how dose one deal with a chimney fire. I am getting mine swept 2 times per year 1 mid season 1 at end of season. I dont plann on having one, but nobody dose. So if it happend what do you do besides trying to shut the air down, wet newspaper.
