I have had two chimney fires in the last two years with my Atlanta Model 26 wood stove. Am using aged, dried hard wood and no sappy pine, get it cleaned annually, etc. The stove pipe goes through about 10 feet of uninsulated (i.e. freezing cold) attic, which I'm thinking could be a contributing factor. Am looking for helpful advice on how to avoid future chimney fires! Thanks.
Joking aside, how does that wood behave when you put it on hot coals? Does it sizzle, steam a lot? Does it take a long time (>5 minutes) to catch fire? Do you have a moisture meter? If not cut a few splits and press the fresh surface against your cheek. Does it feel cold and damp? If yes, it is probably still too wet.
