Hmm, musta changed it...I have 5's in now and I know that was a step higher than the Purolator filters it came with.They call for a merv 5.
That's true...we usually don't get as cold as y'all, or as long, but I have noticed that the house 24 hr average temp is a factor when dealing with real cold temps.Extended cold snaps are tough. Heat loss is exponential.
That was the best read on the internet today. My problem has been the opposite. The Mrs. Here has been going to bed in coveralls lolThat's true...we usually don't get as cold as y'all, or as long, but I have noticed that the house 24 hr average temp is a factor when dealing with real cold temps.
This cold snap this year is the longest and coldest since I've had the Kuuma and I usually load medium sized loads 3X day during real cold weather, but tried large loads of dense wood (like oak n locust) and went to 2X day this year...that worked pretty well too. I did have a couple times where I needed to burn down a large pile of coals before reloading, so I raked them forward and put like 6-8 lbs of half punky oak sapwood splits on it too...raised plenum temps 15* and didn't really add to the coal pile...loaded a full load an hour or two later...might hold the current house temp, might raise it just a bit...but the main thing is that 24 hr average indoor temp...if ya can keep it from dipping, you'll be fine, but once it does, takes a lot more heat to get back to your preferred temp, unless outdoor temps jump up a good bit.
No shame in bumping the fossil fuel furnace on for a bit to supplement, if needed.
We have a stove in the LR fireplace, so I can light that too if I get behind... that'll flat out run you outta the house if running both at the same time! Of course if it gets too hot, the Mrs starts taking layers off, so...![]()
That was with 3 small pieces on when over 30f outside . house was hitting 80's . taking them out didn't really help either it was still to hot after. we just open a window a live with it. it hasn't seemed to have a huge effect on our burn times during this 50 days of single digits loads keeps up just fine.I'd just load less wood vs blowing more BTU's out the chimney.
I don't like them to drop more than 5° or so from max when it's below zero outside. It's not possible when doing overnight burns.yep, once the snowball effect starts (house temps drops, which drops the return air temp which drops the supply temp which causes the house temp to drop more.....), it's hard to reverse.if ya can keep it from dipping, you'll be fine, but once it does, takes a lot more heat to get back to your preferred temp, unless outdoor temps jump up a good bit.
Still sounds high to me...when the HX is clean, and I'm running with computer on low (99% of the time) stack temps get to about 425* with a fresh load, and still on 3, then hangs out around 300-325* on pilot (c) it gets under 300* occasionally too.My stack temps only got to 475 before it lowered as it started cycling down to the c setting. It did lower my stack temps there. I think my stack temps are still fairly high now though as they stay in the 350 to 370 range as it is running in the 1 and c setting.
I do have my computer cranked up right now. You think I need to back it off?
That is just plain weird. Negative, with the way you have it hooked up, means positive pressure. Was their smoke being pushed out of the Kuuma when it was like this?Also, I should be getting a negative number (to the left of the zero mark on the Mano) with the initial load? It did that this morning. But then it will go back across the zero and near a positive .1
