I'm a newbie with a few questions. I've decided to try burning wood as a secondary and emergency heat source. We have a heat-o-lator prefab fire place and I have been researching whether to install an insert or wood stove in the opening. I have decided to install a Buck 74 and a SS liner. I'm pretty handy around the house and planned on installing it myself. There are so many different brands of liners what brand do you all recommend? My hearth is 13 inches off the floor, how do "the do it yourselfers" raise the stove to insert it into the opening? This Buck 74 weighs about 460 lbs. Or is this something that should be done by a professional? Thanks for your time. I look forward to your response.
![[Hearth.com] Chimney Liner and Install [Hearth.com] Chimney Liner and Install](https://www.hearth.com/talk/data/attachments/177/177617-a3d4fe715f93ca8808061e600eba8828.jpg?hash=juSm9ZptaX)
![[Hearth.com] Chimney Liner and Install [Hearth.com] Chimney Liner and Install](https://www.hearth.com/talk/data/attachments/177/177618-3d44a7c85df55e9c6a7f897e8560ec06.jpg?hash=NU1diWKw6_)
![[Hearth.com] Chimney Liner and Install [Hearth.com] Chimney Liner and Install](https://www.hearth.com/talk/data/attachments/177/177619-9640def9f567a2a49275154b2c598536.jpg?hash=V2P8K2wAtY)
); no straps/jack/boards/whatever. But my Carolina Challenge insert is probably a bit lighter than your Buck & I would've used some mechanical advantage if I went the DIY route.
