I decided to go with an insulated 6" flex liner made of stainless steel because I will only have one gentle bend and the bend is barely 22 degrees, not 45, not 90.
Does the liner have to be insulated through and below the block-off plate? It will only be about 8 inches between the block-off plate and the top of the stove, by the way.
My exterior-wall brick chimney is 10 feet tall from the block-off plate to the top. I do plan on buying some sort of 3-foot solid extension pipe to add to the top to bring my total chimney length (bottom of stove to exhaust) to the required 15 feet. Does this extension also need to be insulated?
Thank you!
Thank you!
