Chimney Liner Material 50/50 corn mix
NorthernCrew454
6
NE wisconsin
Hello all,
I recently acquired a Winslow PI40 insert and the manual states it can be used with up to 50% corn mix and pellets. Will a 316L liner be sufficient or will a 316Ti be required due to the corrosive nature of the corn?
Thanks
NC
Comparison of the two metals: (broken link removed)
First paragraph on page two would cause me concern on the 316Ti as it doesn't seem to have as high pitting resistance... but it is purportedly better at higher heat. What's the cost difference?
From the manual (in case you don't have it yet):
(broken link removed to http://ironstrike.us.com/system/document_files/files/000/000/372/original/900139-00_A_PI40_EN_IICO.pdf?1430839189)
Venting This fireplace insert is approved for venting with Type L and Type PL pellet vent pipe (listed to UL 641 and ULC S609) or listed pellet flex liner (2100HT [degree F.] liner listed to UL 1777 or ULC S635). The insert’s flue collar is 3” in diameter. The insert’s combustion blower pressurizes and pushes flue gases out the pellet pipe. All pipe joints should be locked together or screwed with three screws if the pipe does not have a locking system. The pipe joints can be sealed with high temperature silicone if there is a possibility of flue gases leaking into the living area. The pipe should be fastened with three screws to the insert’s flue collar. The longer the run of pipe and the more elbows used, the greater the resistance to the flow of flue gases. Four inch diameter pellet pipe is recommended for pipe runs greater than 15 feet or when a number of elbows are used. A 3-4” increaser can be used to connect the 4” pipe to the 3” flue collar. The outside air pipe may run up the chimney, horizontally, or down provided the structural integrity of the fireplace and chimney system are maintained. DO NOT INSTALL A FLUE DAMPER IN THE EXHAUST VENTING SYSTEM OF THIS UNIT. DO NOT CONNECT THIS UNIT TO A CHIMNEY FLUE SERVING ANOTHER APPLIANCE.
Another opinion: (broken link removed to https://www.rockfordchimneysupply.com/blog-2/flexible-chimney-liners-explained/)
(broken link removed) (down the page about 3/4)
