All,
I've been searching for info on chimney sweep equipment and the majority of what I see comes back to people here discussing the Soot Eater system.
I've read several concerns with these that usually come back to the length of the brush "strings" in that they should be nearly fully extended in order to be effective, but getting the length trimmed "right" to cover a while chimney system is next to impossible due to bends and, in some cases, people have non-circular flues (ovals seem to also be common).
What I want to do is cover 6", 7", and 8" round flues. I intend to clean from the top down = get on the roof, pull the rain cap, etc. For any bends my intent would be to set up the piping with the intent of disconnecting for cleaning so that should be easy, should we get that far. Otherwise, a straight vertical chimney run is the main concern.
My initial thought was a set of brushes like what Rutland makes - they have poly and steel wire brushes.
A lot of the discussions surrounding chimney sweeping are from people that won't get on their roofs, so they are all coming from the perspective of cleaning from the bottom up.
Is there anyone here that can offer any input from cleaning from the top down and what results they have had with what types of brushes? Thinking in terms of the worst case scenarios with soot coatings and gunk adhered strongly to the flue pipes - what is the best bet for getting through the hard stuff?
