Hi Everyone!
Been reading the forum for a while but this is my first post so I would just like to start off and say thank you for all the amazing information. It has truly provided a very short learning curve to burning wood and using a wood stove.
So I have searched the forums for days trying to find my specific situation with no luck, so I really hope I’m not reposting a topic but I tried.
I am burning an early 90s (92-93) Hearthstone Phoenix given to me by my father from his house in Vermont we grew up visiting.
When burning I am getting basically conflict between my stove top thermometer (StoneGuard) and my Chinney thermometer(Chimguard), or at least from what I read on here I should be seeing.
Basically when the fire settles down from a reload (which I usually have to crack the door for about 90 seconds to 2 min to get really strong flames) my stove will get cooking HOT (450-500+) but my Chimney temps will barely want to stay above 225-250 degrees.
When I reload I will let it climb back up to around 350-400 and then close the door tight, the stove will keep cooking hotter but chimney temps drop right back down just about 200.
Now burning during the day I will continuously check the chimney outside for smoke and there is usually none to at worst a light whisp of smoke blowing around when I reload but most of my burning is at night after work and all I really have to go off then is my thermometers.
I am burning delivered white oak but everything I put in the stove is split in half before going in the stove and checked with a moisture meter. 95% of what I have put in the stove is between 16-20%. At worst I have put a couple pieces in around 21.5% that I split very small.
Can anyone give me any insight? Is this a problem, should my chimney temp be more relative to my high stove top temps? Or is it all fine as long as the stove box is burning hot with flames?
Thank you!!
Thank you!!
I sure wouldn't want to see 800. The manual for my KeySTONE says 700 but I wouldn't want to see that either. I've had it to 600 but not often.
