Classic bay 1200 FS shuts down after 10 minutes
Buc White
73
Connecticut
Good morning everyone. I have a classic bay 1200 fs that was purchased in 2010. The stove ignites and drops pellets for about 5 minutes after igniting then shuts down. I changed out the thermocouple with an oem part and that didnt work. Had the vacuum switch replaced with an oem part and that didnt work either. If i push the reset button once while the stove is running the stove it cycles again and will alow for the blower motor to come on but will shut down after 5 or so minutes. I cleaned out the vent pipe and the entire stove including under the burn pot and behind the combustion chamber.
I had a tech out to my house and he was a nice guy, but called someone every step of the way. He originallly thought my stove would be dirty and that was not the case. Dont know if he really knew what he was doing. Could this be a snap disc issue? Any help is appreciated
https://downloads.hearthnhome.com/installmanuals/CLASSIC_BAY_1200_PELLET_FS_OWNERS_7014_259.pdf
Might be the control card, or bad connection to the thermocouple. The snap disks are for other things. You probably have a proof of fire issue.
