Cleaned Chimney late tody
NextEndeavor
Burning Hunk
248
Southern Iowa
After work I removed the grimy rain cap and did the brush thing several times. This is a fireplace insert where the liner drops straight down to the top of the stove. The liner and top 4 foot double wall insulated section looked real good before starting the sweep and now looks great. The two pictures of the stove inside indicate I didn’t even get enough creosote to fill a 24 ounce bottle, but the cap was a total mess. I have burned 24/7 for 6 straight weeks since the last cleaning. Needless to say, I’m running tonight without the cap wondering what you guys think. I don’t want to leave it off when the rainy season hits but for now we should be fine. So do you think I have typical deposits on the cap? My wood burns just fine with only some smoking but seldom sizzling of water out the cut ends. Thanks
  • [Hearth.com] Cleaned Chimney late tody
That looks crappy for 6 weeks of burning. From how you described your chimney condition it sounds like:
1. You have about a 50' liner or
2. Your burning unseasoned wood
I would not be happy if I found my chimney or cap looking like that . . . glad you cleaned it.
They all get "dirty" and occasionally I'll get a drip with the right weather conditions, but never a cap which looks like that.
pen
The flue is about 17 foot long, a stainless steel liner inside a masonry chimney on the outside of house. It is not insulated except for the last 4 foot where it continues out the top for better draft. The chimney is clean, take a look at the small amount of creosote that fell into the stove during the sweep. My wood is probably average to slightly wet. I oven dried a couple loads checking weight before/after and came up with about 20% average H2O for the red oak, 10 percent for the yellow hedge.
The cap looks bad, but I think it's as much from design of the cap and because it's an outside chimney. The cap looks like it is too restrictive to airflow, so it will really collect the creosote on it. I didn't think the amount that you had in the stove was overly excessive. I would change the cap, and make sure you are burning seasoned wood for next year and you should be fine. Just my $.02!
I use to have a very tight chicken wire screen in my cap and it would clog up quickly. Every time I would check flue no creosote. Get rid of that cap.
The cap can be used as a good barometer letting you know how things are going. IN this case, it is saying your wood should be much better next year as it isn't good this year. btw, we put up a new chimney and cap in 2007. The cap has not been cleaned yet.
The cap can be used as a good barometer letting you know how things are going. IN this case, it is saying your wood should be much better next year as it isn’t good this year. btw, we put up a new chimney and cap in 2007. The cap has not been cleaned yet.
I agree and disagree. I've gone a full season without cleaning my flue, just visual inspections. My cap plugged up constantly when I had the tiny chicken wire on it. OP is that wire or solid on cap screen? I just cleaned the flue last week for the first time this year, only reason I did was because I climbed on roof and hauled brush and rods. Had less than half a coffee can of creosote. Better safe than sorry, I would still suggest if you are using seasoned wood and cap clogs take that screen out. Screen plugged up using old ashley, wonder if new epa stove would do the same? I'm not gonna find out though that screen went to scrap yard along time ago! Lol
My cap has looked like that twice this season. It's my first year and I've been burning some questionable wood. I just check it more often and clean the cap and chimney as needed. Now that I found hearth.com, I'll be better prepared for next year.
If you burn to low a temp will that also happen???
That happens some time with less than stellar wood. I have the sister to that stove and burning practices can have something to do with it too. This happens to mine because I have to throttle the stove down a bit much in shoulder seasons...
