cleaned the chimney liner
Cleaned out the bottom part of the Liner. Now everything is open is there a way to check the draft of the chimney liner.
In this kind of weather there probably won't be much draft, that will change when it cools off.
Are you having problems? What's your set up like? It can probably be diagnosed without checking the draft itself. T's, 90's, flue size and the height can all greatly effect your draft quality. Any pictures would be helpful to.
I think I had to much soot...But was just wondering if there was a guide you had to go by. I think my chimney is 14'-16' included the stove connection.
  • [Hearth.com] cleaned the chimney liner
