Hello and Happy New Year to ALL!
I am very due, if not overdue, to clean my 6" SS liner. It's all straight forward, except my Drolet insert makes it a PITA. It seems that I am supposed to remove the re-burner air tubes in over to get up into the top of the unit, where there is a piece of wool and a weight directly under where the liner joins the unit. If that's not enough of a pain, I read that the wool will likely need to be replaced once I mess with it.
It sure seems a heck of a lot easier if I could clean the liner from the roof with a brush and then drop in a hose attached to my shop vac to suck up the crumbs, no? Is this possible or should I just order up a replacement wool and get to work?
Does anyone else with this unit have a best method that they've found??
Thanks in advance!
Wally
Thanks in advance!
Wally
