Hi,
I have been scouring the web, but I can't find the answer: if I install a woodstove in the corner of the room, and put in a heat shield to reduce clearances to the wall, how far does the shield have to extend beyond the stove, on the sides?
It is a Drolet Savannah, the clearances are 12" from each corner to the wall, but per the company this can be reduced by 67% by putting in a metal heat shield. Said shield must extend 20" above the stovetop, from 1-3" above the floor, and 18" on either side of the stove. Where do I measure from for the side measurement? Since the rear corners are closest to the wall, do I measure from there, or do I measure from the front of the stove, forward along the wall (subjectively, this seems very far)?
Thanks for your help! I want to make sure everything is right before installing it, and the shield will not be very attractive if we have to add pieces, later.
Mary
Mary
![[Hearth.com] Clearances question [Hearth.com] Clearances question](https://www.hearth.com/talk/data/attachments/97/97150-5f3526d7ec6d219c098bf76a85e93e1a.jpg?hash=fnYYugGjvG)
![[Hearth.com] Clearances question [Hearth.com] Clearances question](https://www.hearth.com/talk/data/attachments/97/97151-9f5736af51c70d76967914fccdea787c.jpg?hash=FxfAJW1vTO)
