I had my Clydesdale stove installed last week and have been heating my house for one week. I have been pleased with how much heat I get out of it, but I dont think I am using as efficiently as possible. I seem to reload with wood too often. I have tried different ways of loading with not much change. I know everyone will probably say it the wood, but my moisture content of the wood is between 4% to 12%. It is most likely operator inexperience. I have a infrared red heat gun and have been monitoring temps on top on stove centered just under surround. Heres what I have tried and the results
Stove temp at top 400
Adding only 2 logs, split coals to left and right to allow air up center, air opened up 1/2 way, good heat but adding wood every 1 1/2 hours
Stove temp at top 500-550
Adding full load of wood, split coals left and right for air, air opened 1/4 way, good heat but stove top temp will drop over burn time. Burn time to reload is maybe 4 to 5 hours.
Over night burn
Start with a bed of coals and stove top temp around 300
Split coals again, fill with wood, shut air all the way down. After 7 - 8 hours stove temp is around 150. I empty out what coals I can, split hot coals and can get a fire going again with-out kinling.
Pleased with the heat but seems like I am using more wood than everyone else and far less burn times to reloading. Any advise
Over night burn
) wake at 6am to coals and the blower still blowing warm air-add more wood and off she goes again.
