Coldest temp of the year
Robins are year round residents here. Anna hummingbirds too if you keep a feeder always available.
Sparrows shivering at the bird feeder today in sub zero temps. I forgot what the lawn looks like.
-27F and -45F WC so they say tonight. Snap, crackle and pops will be heard from the trees and the house expanding.
I read that in Duluth MN. it got down below zero 60 days in a row this year.
what the gfs thinks about a week away!!!!!!
[Hearth.com] Coldest temp of the year
Calling for -4 tomorrow morning and minus -3 next wednesday morning. Which would match the record for march 5, 1978
It's a nice, bright breezy day, full of sunshine, and negative 7 F.
Immo be outside all weekend. Single digits in the morning. I will be burning 2 1/2 bundles of trim however, so I should keep moving and near the fire
All this will be gone before Monday
I've always liked Duluth. I could retire in one of those small houses that back up to the beach. Duluth, MN. My kind of beach town. :)
[Hearth.com] Coldest temp of the year [Hearth.com] Coldest temp of the year
Here is a graphic showing the frost depth in the 70-75" range in Minnesota which would explain why so many homes water lines are freezing up this year there leading to the second picture showing a city worker trying to thaw a water line in a home.
Yikes, 6 ft of frozen earth? Will that thaw out before next winter?
It should once summer comes and there's heat below and heat above but footing work will be delayed some I'd guess.
They can have it. I mowed the lawn today. Let springtime begin.
That frost depth is under pavement. The frost depth should be much shallower under our deep snow. My septic pipe hasn't froze yet but I cover it with straw before winter and it has a lot of snow on top of that.
My sister says That it's been nice in the Portland OR area lately and that I should come out since it was 1977 since I've been their to see my Nieces.
Nope, nope BG. It can't start to slowly warm up until the end of March. We need a steady -30 until then. Plenty of pipeline breaks to fix.
From the picture I posted showing the city worker trying to thaw a water line, they said they can thaw about half of the lines that way. The rest need to be fixed by a private contractor meaning a expensive digging job I'd guess.
Worried about my septic. Dug the hole to the opening in the tank in September and the fool didn't show up. Open hole over the top of the tank with record setting cold here for months.
Yes Wisc, good reason to put them in deep & only bring them up after they are in a heated structure.
If it has a lot of snow on top that should help insulate it.
Don't worry about the septic BB they make their own heat, just don't have it pumped out until it warms up.
Thanks. What I was thinking. I covered the hole with plywood.
A contractor nightmare. Dug the hole and scheduled the pumping. Scheduled the re-graveling of the 900 foot driveway and the re-roofing of the house. And did the schedule of the driveway and the septic for two weeks after the promised date of the roof so they wouldn't be here getting in the roofer's way. And then the roofers kept putting it off for six weeks and the the driveway and septic guys told me to F off.
Didn't cost me. Just them. But still...
The tank will freeze up here, mine did 7 or 8 years ago when we had plenty of cold but no snow yet. I was only using the house on the weekends then so not a big deal. But a neighbor had his tank and pipes freeze up last year and in the process of thawing it by the pumping company he had to use his ice auger to drill a hole in the ice so they could pump it out. I'm talking a holding tank, not a conventional septic system. Same for mine, 3,000 gallon tanks that cost $145 to pump when full.
