Anyone else using one of these yet? It’s the first season of use for me and first pellet stove, as we’ve had electric heat the past 7 years. So far I’ve only burned about 10-12 bags of pellets and I’m overall happy with the stove. However...every 30 seconds to a minute there is a loud clunk/knock. It’s seems to be coming from the auger.
From the research I’ve done, this stove seems to share the same auger/auger motor with castle serenity stoves. I found several threads on here with castle owners with the same weird noises, but no updated the thread with any solutions or even if they found the culprit of the noise.
Other than the noise, the stove seems to be working as it should. I called Comfortbilt a couple weeks ago and their Tech suggested loosening the set screw and bearing down on the auger and re tightening the set screw. I attempted to do this but the auger is pretty much bottomed out on the auger motor shaft so really no where for it to go.
Anyone have any suggestions or fixes for the noise? Since it’s running fine is it even worth worrying about or attempting to find a remedy?
