Good day everyone!
OK, I'll try my best not to get too wordy but I want to explain myself fully as well as provide what Information I can.
My wife and I currently heat 100% of our home (aprox 2600 sqft) with a PE Summit Classic. We got the stove 4 years ago (going by memory, so don't hold me to that number) and we are very happy with it.
Since that time, we've added a 400 sqft addition to the home. This addition is currently unheated and can be closed off from the home with a set of exterior double doors but we are thinking it would be nice to heat it on occasion for two reasons:
1. Just so we can enjoy the addition in the winter months as well
2. During really cold days, we can open the double doors to the addition and use whatever woodstove we end up putting out there as supplemental heat.
Now onto an idea that I'm hoping to get some feedback on from current blaze king owners.
I'm thinking of removing the PE and replacing it with a Blaze King, King model. And then putting the PE Summit Classic into the addition. My reasoning is this; although the PE has been a great stove we do find on really cold days it's at it's limit. Also, since we are 24/7 burners from basically October to early April, loading the stove only once a day as apposed to 2-3 times a day seems very appealing.
The current home is 2x6 construction and we re-did all the windows a few years ago. The ceiling is currently R30-35 which I'm hoping to add to soon to bring it to R45-50.
The addition is similarly insulated except the ceiling, which is cathedral and will only be R28.
Our winters can get fairly cold (-35F to -40F on some cold nights in Jan Feb).
The blaze king would be going into the existing location of the PE.
The chimney is quite long (roughly 22' in the straight section) but most is exterior and there are two 90 bends in the basement where the flue comes up from the stove (about 3') then bends horizontal and exits the wall. The chimney then bends another 90 to go vertical again, from there it's straight up about 22' feet.
The PE does fine with this chimney but the Blaze King is a CAT stove so I don't know if it will be more sensitive to drafting etc?
I know the PE will have no problem heating the addition as well as supplying extra heat to the home so I have no fear using this stove for this purpose.
My questions to all of you is how well do you think the big King Model will do as our new primary heater?
Is it as good as all the hype?
What sorts of downfalls or learning curves should I watch out for (one down fall already is my wife doesn't care for the look of it, but if that's the biggest concern we can live with that), especially considering we're moving from a non-CAT to CAT stove?
I know wood dryness is always a concern with ANY stove but it seems to be an even bigger concern with a CAT stove? Consider how much space we currently heat with our PE I'd say our wood is dry but is a CAT stove that much more difficult to deal with regarding dryness? I sweep my own chimneys and have almost no creosote build up each year so I suspect our wood is well seasoned. But again, I have zero experience with a CAT stove.....
I'm hoping to hear of someone in a similar climate with a similar sized home who is currently running this model but also welcome any information any blaze king owners can give us!
The last thing I want to do is change the stove we're currently quite happy with only to find we really haven't gained much.
Our other idea is to simply leave the PE as is and add a smaller stove to the addition (maybe a woodstock or similar).
Sorry for the long post!
Thanks folks, keep up the great work!
Cheers....
BLT
Cheers....
BLT
) layout of the home:
