Hearthman said:I don't pass or fail chimneys---I inspect them. Have I ever found a single chimney that did not have some sort of issue? No. Have I found any that ever met 100% of the applicable building code? No.
The prosecution rests. Cya.
Webmaster said:Personally, I would first have a local building inspector or fire dept (some do this)...or chimney sweep, inspect the flue and tell you whether it is OK as is. If it needed lining, I would probably use single wall without insulation due to fit issues. This would effectively give you double lining - the existing flue tile and then the ss.
If you see orange or red tile sticking out the top.....then it is lined.
Carl said:Not necessary so. I built my own masonay chimneys back in the 70's and lined the one for the wood stove with tile, but not the one for the fueloil furnace. It didn't need lining but I did stick a flue liner out the top for looks. You need to look down the chimney to see the lining and it can be inspected with a flashlight and mirrow to see if any tiles are cracked, broken, or just not there.
tunaman4u2 said:Thanks guys.
Maybe I should have been more clear... I don't think I have terracotta because there are no tile. Maybe its solid clay liner sort of like this...
(broken link removed to http://www.superiorclay.com/flue-liners.php)
BrotherBart said:The 30-NC, painted the right color, is the prettiest wood stove on the planet. :coolgrin:
fossil said:BrotherBart said:The 30-NC, painted the right color, is the prettiest wood stove on the planet. :coolgrin:
How do you know which is the right color for the planet you're on? :gulp: Rick
BrotherBart said:fossil said:BrotherBart said:The 30-NC, painted the right color, is the prettiest wood stove on the planet. :coolgrin:
The little brown haired lady I am married to. Only female I know that thinks steel stoves look great.
tunaman4u2 said:I have a little blonde haired lady who thinks steel stoves are ugly! How can I trade for one of these brown haired ladies you speak so highly of?
hh: Rick
tunaman4u2 said:FOLLOW UP!...My blonde haired lady likes the look of a sand stove much better![]()
) RickWe use essential cookies to make this site work, and optional cookies to enhance your experience.
