Hey guys,
First post here! I've been lurking for a while and want to thank everyone who has contributied to this forum. After much reading I've decided I will most likely get a new fireplace insert and perform the install myself. However I have a couple questions still.
This is the Napoleon 1402 insert and it sticks out of the fireplace about 9 - 10 inches. Which means I'm going to have to extend/redo my hearth. So Question #1: Can I just buy one of these hearth pads from Northlineexpress and place that on my floor? It's 1 1/4" thick. (Also I've heard that directly below the insert is actually one of the cooler spots of the insert. I've always thought it would be the hottest. Is that true?)
Here is a link to the hearth pad:
northlineexpress.com/champagne-cork-48-x-48-double-cut-hearth-pad-ccdc-4848-19607.html
The manual for the insert states:
HEARTH EXTENSION / FLOOR PROTECTION:
Must be non-combustible and extend in front of
the insert and 8” on both sides with a minimum
thickness of .500” and a thermal conductivity fac-
tor (K) 0.84.
Question #2 is regarding the firebrick inside my fireplace. This insert is basically square but inside my fireplace the side walls are at an angle. And I don't think this insert will fit inside my fireplace with the current firebox/firebrick the way it is. Can I remove some of those firebricks on the side and back?
The manual says don't remove bricks from your chimney. But it isn't clear if it's referring to the actual bricks that make up the structure of the chimney or if that includes these firebricks.
Here is a link to another fireplace on this forum that has a similiar firebox as mine:
hearth.com/talk/threads/build-log-napoleon-1402-liner-install-sheet-metal-damper-crown-repair.147231/
And on a side note, my firebricks are cracked and there is very little mortor still there. If I continue to use this as a fireplace as it is now can I use high heat mortor caulking and and just seal those fire bricks up and be good to go?
Thank you!!
tor (K) 0.84.
Thank you!!
