Creosote in fire box
And the end range of the cat gauge is not an issue; you have a new stove, with a new cat. They often are still hyperactive, meaning they get hot, HOT. That'll settle down when they mature out of their teenage weeks...
For me I reached "steady state" in cat behavior after burning about a cord of wood.
Basically it's fine. It'll settle down. If after a cord of wood you regularly go beyond the scale, then I'd think you have something worth looking into. Before that, it's okay.
This is why they don't give numbers on the gauge; it's just a binary "do I need to close the bypass or not" indicator.
Reactions: vallieweck and Tron
That's exactly it: with the BK, you don't vary the load size to adjust temperature. That's because the thermostat does that, it varies airflow to set the combustion rate. You stuff it to the gills and set the thermostat accordingly and just let it be.
Of course, there's a limit to where you can dial it down, at some point the cat will drop out of active range. But that's entirely independent of the amount of fuel in the stove.
Turned down, the flue temperature is not a problem at all. Like I said, I mostly use it after a reload as not to overfire the flue/bypass with the bypass open. That's something that can happen, the bypass door hinge and gasket don't like having the door open and the thermostat at full for extended periods of time. I do that just enough to get the load going and then close the bypass and dial down the thermostat.
But a flue thermometer is easily installed: just drill a 1/4" hole through both pipes and stick this in there:
Thanks for your insight. What do you think about the creosote in the firebox?
Sooooo much to know! 😂 I bet I’m right around a cord at this point. You were the one who said creosote in the box is part of the low and slow lifestyle right?
I'm not sure those are my words, but I could have said them.
Just follow the flow of air/gas.
You create creosote in the firebox (if you burn slow). You clean it up with the cat. So between the location of creation and the cat, you'll get dirty. That is firebox and windows.
I can get my window clean (enough) in 20-30 minutes. My firebox needs more time and I only do that at the end of the season (or naturally during polar vortex events :p ).
Oh no, that wasn’t you. You were the one talking about a full load and letting it rip! I can’t get my window clean AT ALL. Like I said, burning it hot for up to an hour, does nothing…
Reactions: stoveliker
Nothing, really.
My firebox is also full of creosote, especially on the sides behind the plates. I use a bottle brush to clean that out at the end of the season.
My glass is also mostly dirty, as it's been said that's just the way it is when burning low. Sometimes when I empty the ashes I take a razor scraper and mechanically clean the creosote off, but it never lasts very long.
Everything looks normal. Take that stove top meter off, it’s just a useless distraction on this cat stove.
Reactions: Tron
Thanks much, I think this is good advice and seems to be familiar to what I’m seeing on other threads.
I've burned lots and lots of doug fir in my BK and it does just fine. Currently burning 100% maple and the firebox looks the same but the chimney is a bit browner vs. the more sooty flue when on fir. 18% is just fine. Here in wet western WA we can only get it down to about 12%.
I tried to use a stove top meter but it drove me nuts because the catalyst runs really hot at low stove settings. Then at high stove settings the whole thing runs hot. It basically always read about the same temperature. Now on my noncat, you can actually operate the stove with one.
Reactions: Tron and stoveliker
I posted a short video last year about this very issue. Creasote buildup on the sides of the princess behind the baffles. It is not an issue and so long as it is in the firebox there is no issue. I clean mine at the end of the season using the tool in the thread. Others used a bottle brush. Either way, keep burning dry wood and enjoy the warmth.
Made a short video on what I hope is a helpful tip to clean out some of the creasote from our Princess Models. There are deflection shields on both sides of the chamber above the bricks. Creosote can build up in there, and while probably not dangerous, it can build up over time. I use a plumbing tool to help my clean this out as seen in the attached video. Enjoy.
Hello all. I run my BK hot for about 45 min on cold start or after reloading, STT at around 600-650 and then I start turning down the thermostat for temps to run around 400. Is it normal to still have creosote like this in the fire box and on the glass? Burning fir at 18%, I would like that to be drier but it’s what we have, still in acceptable range.
Thinking about using rutland’s creosote spray during a cold start for when catalyst in bypassed. Thoughts?
Thank you in advance!
Inside of my stove looks similar and so does the glass. I burn pine and juniper. Maybe every other month I clean the glass with ash from inside the stove and wet paper towels. Cleans the glass right up, only to return during the next burn! Regarding the creosote, if my stove ever cools down during a warm spell I'll get in there with a wire brush and knock some of it off and then vacuum it out. I don't go nuts, just go at it for a minute or two and get the easy stuff. My Sirocco 30.2 tens to build up creosote along the back wall of the stove the most. I don't worry about it. Inspected my flue and chimney yesterday and after a year and a half of burning it's super clean.
I’m going to give it away, it’s throwing me off as well and I’m not sure it’s doing me any good. I really just want to know if I could be burning too hot, so I may need to get a flue reader???
Reactions: Highbeam
Thanks for the note. No way the ash and paper towel trick works in this situation, I’ve tried! Yes, I guess I’ll just keep my worries to the flue at this point!
That’s so funny, this video helped me so much a few weeks back!!! I used your method and it was as addictive as peeling a sunburn. I just couldn’t stop. Glad that I have an opportunity to thank you for that!
If you're talking about the blacked glass door, then you're right.
I use a razor scraper and that works pretty well.
But only occasionally, because as it was mentioned it quickly returns on the next burn, so there's really little point to it.
Maybe if you expect visitors or something ;-)
  • Haha
Reactions: GG Woody
