Sounds like the Progress....It would be nice to see a cat-stove that was actually easy to maintain -- without tools, from the front & with chimney/stovepipe cleaning ease!
Can it be cleaned bottom up for those that can't or won't go up on the roof? If yes, what is entailed?I clean top down with the bypass open. I can then reach up with my hand and get everything that doesn't make it into the belly of the stove.
Yes it can. With a viper or sooteater. I do it all the time.Can it be cleaned bottom up for those that can't or won't go up on the roof? If yes, what is entailed?
Pull your pipe up some time. You'd be surprised what's laying between the bypass and the backside of the cat.I clean top down with the bypass open. I can then reach up with my hand and get everything that doesn't make it into the belly of the stove.
Don't need to. With the bypass open I can push the bypass plate up enough to clean that area.
The inserts not bad at all since it had an angled flue collar. But on a stove I always pull the pipe up and sweep this area from above.I clean that after every chimney sweeping. I stick a shop vac hose up there, and brush the crud into the hose with my fingers if there's a lot of it. (It has just occurred to me that I should fabricate a "U" for my shop vac, and I could clean it without the brushing.)
You always want to vacuum the face of the cat anyway. So yes, sweep away!Can't soot get onto the cat? Just vacuum it afterwards?
The flame shield?I can take the angled guard plate off mine and shine a flashlight in there, and actually see if there's any crud left.
One reason is because of the thermostatic control. It's extremely difficult to pass the EPA testing. Each pass/fail costs hundreds and hundred of thousands of dollars. Ever wonder why no one else is doing it?Thanks for all the critiques.
One big question: why are BK stoves much more $$$$ than similar stoves with similar specs ?
Can't be, VC had a thermostatic control +/- a couple of decades ago. Even those creosote makers Ashley had one.One reason is because of the thermostatic control. It's extremely difficult to pass the EPA testing. Each pass/fail costs hundreds and hundred of thousands of dollars. Ever wonder why no one else is doing it?
I'm well aware of that.....Can't be, VC had a thermostatic control +/- a couple of decades ago. Even those creosote makers Ashley had one.
So why so much more $$$ ? All wood stove makers have R & D and ISO regs and quality control and marketing and .....
I can guarantee you the majority of actual BK owners here would not hesitate to recommend or buy BK again.
Good deal. Is this with the Princess, the Ashford or both? What is the process?Yes it can. With a viper or sooteater. I do it all the time.
![[Hearth.com] Critiques of Blaze King Stoves...Exist ? [Hearth.com] Critiques of Blaze King Stoves...Exist ?](https://www.hearth.com/talk/data/attachments/189/189340-7173e90e1718841b3913740b918ce357.jpg?hash=0xPb-acRLu)
All BK's can easily be cleaned from below. Just open the bypass and sweep away!Good deal. Is this with the Princess, the Ashford or both? What is the process?
