Disconnecting insert from liner
excessads
Burning Hunk
Feb 16, 2016
222
Garden State
So....we smell odor from the fireplace wall which was coated with soot E en after installer repair exterior masonry work so moisture is not supposed to be seeping in. The fireplace wall should have been cleaned before insert installation but we didn't think it would have been an issue.
Now I want to have the insert disconnected from the liner and scrub the wall ourselves. I wasn't home when the install was done. Is this something I can easily disconnect and reconnect w/o forking over several hundred dollars?
The insulated liner is in the chimney, I figure using a block off plate, roxul and sealant to completely seal anything above the insert where the damper plate used to be as a last resort to seal off all odor. Anything you can think of w/o removing the liner?
Sent from my XT1254 using Tapatalk
Take off the surround and see how it was attached, most of the time the liner is attached with L brackets to the top of the insert. Shouldn't be too hard of a job, the fun part is going to be putting it back in depending on how tight of an install it is.
You will see a big difference once you insulate that fireplace.
you really need to clean the fireplace and see if the flue is dirty. if so that needs cleaning as well
