DIY crawlspace Passive/Active Radon motivation advice
ylekyote
94
I have a 27 x 36 foot rectangular crawlspace that has bare dirt floor. It reads around 30 when I conduct tests for 48 hours.
I want to place 191' of 2" ID ABS irrigation pipe in crawlspace in a grid pattern with 4 cross laterals. I was going to run a 5" solid ABS plastic pipe from CS floor to most top place on roof, that's 22' of vertical rise of a 5" plastic pipe.
Temperature under the membrane is 42 deg F coldest Winter (frequently around 50), and about 50-55 deg F at hottest in Summer.
I'm not sure how close/size I should drill the drain-sunction holes in the horizontal pipes on the ground. I was considering every 1 to 2', in a spiral type pattern, so that water (if ever) can always escape nearby. And 1/2" dia holes. Any ideas?
Does anyone know a formula or other means to calculate what size and length horizontal pipe is required for enough suction from the soil, based perhaps on sq footage? And size/frequency of drilled holes?
I'm planning to install 5" Vertical pipe 20'/up side of house.
How do I figure the math to plan and lay horizontal/vertical pipes to provide enough draft to vent the radon trapped under the vaper barrier on floor, up the radon chimney?
Every system I've seen has a powered vent.
There is also a gauge that does show a pressure drop from the fan. I'm not sure if this is to show that it is working or that there is a certain figure they are looking for.
Maybe a call to the building inspector will give you the answers you are looking for.
I'm not sure where you are so what your climate is...
Would it be easier to isolate the living area of the house from the crawl space and then vent the crawl space?
You might get an added energy use and comfort benefit.
maybe ask the guy at Indoor-air-health-advisor.com
he helped me design a (much simpler) system for my house, and generally seems like a helpful/knowledgeable fellow
