- Oct 3, 2007
- 1,539
I had always thought of mini splits as being way out of my reach because of the fact that a pro had to vacuum/charge them. Now apparently there are more than a few manufacturers offering DIY systems that are pre-charged, you just install the inside and outside units and carefully run the lines, connecting them with a special quick connect that keeps the refrigerant in and air out. Frederich is one of them:
(broken link removed to http://www.friedrich.com/products/residential/window/breeze/features)
I watched an install video online-looks to be about as simple as it gets-you just have to be really careful about not kinking the lines The only thing I don't like is that they are not made to be hardwired (the smaller units do run on 110V), so there will be an unsightly plug on the wall, but that's a minor thing. These seem like they'd be a perfect solution to our planned master suite addition (currently an attached garage). The small unit can be had on Amazon for $1800-MUCH less than extending my existing ductwork to the garage and upsizing it to accommodate a 3 ton AC unit to handle the extra square footage (oil/wood furnace would be plenty big enough). Any hearth.com'ers install one of these units?
