With our new FPX 36 install we received a moisture meter (a moving LED model, never seen this anywhere else). It seems to read very much on the dry side, but I have nothing to compare it to. The go/no-go test is two fingers, which reads around 15-18%. Oak that has been seasoning for a couple of years usually doesn't even get it to the first (7%) LED. A split of a small cedar log on the property, that had been sitting outside for who knows how long, showed 10-11%. From all I read, these readings sound pretty low. One possible issue is that the manual says drive the pins 6mm into the wood. Well, that is simply impossible, either into the ends or into the split side. Maybe 1mm is all I can get. No idea how much that will affect the readings. Any thoughts on all this?
