Door adjustment on PE T5
Grinnell
68
No Colorado
my door seems a bit too low and i have to push hard to close it which is bending the door latch on the stove. The manual had nothing on door adjustment. looks like if i can raise the door a bit it wouldn't need the extra push to close.
Any ideas suggestions. Searching didn't find anything.
thanks
k
The good news is the door is adjustable. There is a good posting on this. I will have to search a bit for it. The bad news is that I think you may need to unbolt the right side panel for bolt access.
Got it. You may not need to remove any panel. Open the door and you should see the bolt that adjusts the door above the hinge. Check to see if it has loosened up.
https://www.hearth.com/talk/threads/35145/
Thanks,
i searched t5 door, t5 door adjustment, and just got tons of posts.
k
