I wanted to share an easily reversible modification I made to my Escape 1500i in case it helps anyone else. This is my second year using the stove and it has been an incredible stove for me apart from one recurring issue. A large load of wood (almost exclusively oak for me) inevitably reaches a point in the burn where the flame starts to run away, the stove gets too hot and the wood burns up too quickly. This happens despite having the air control fully closed and a key damper installed in the pipe above the stove also closed.
With the air control fully closed on this stove, there is still a significant opening in the air intake. I've heard they tuned these stoves based on a 15 foot chimney and allowing them to breath a little more helps with emissions (at the expense of burn duration). I have a 25+ foot straight shot chimney so in my case it's just pulling too much air. I've heard of people covering the doghouse holes inside the stove box but I didn't want to throw off the airflow balance within the stove so I wanted to find a way to control the air upstream. I made an easily removable "clip on" part that clips to the moving plate that covers the air intake when the air control is closed. Because it is tucked back under the stove, I had to make it about a foot long and as a result it can be pulled off easily if needed.
The result for me was a much more controllable flame, a longer burn, and a much warmer stove in the morning than I usually wake up to. The video shows what my flame looked like when it reached its apex. Normally this is where the flame would be roaring. I'll likely remake the piece with a bit thicker metal and some rivets instead of bolts but the proof of concept worked as well as I could have hoped for. Although mine is the 1500i, I'm sure the air intake is the same or similar to the other Escape stoves. Hope this helps anyone having the same issue.
