My backyard experiments suggest it's probably better to cover sooner rather than later. Last summer I regularly weighed and tracked several uncovered splits of various species, and they all got heavier whenever it rained and then took at least a few days to lose that moisture.
The direct sun exposure you gain by having them uncovered only affects the top row of spits; the rest are shaded to the same degree regardless.
By the same token, unless the rain is blowing sideways, I think most of the rain falling on top of the stack runs out to one side or the other by the time you get down a few levels. I'm stacking some wood in a good sun and wind location but don't have experience with drying in these conditions, as most of my stacks are in the woods. The surface of the wood seems to dry out pretty quick after a rain in this good location. I haven't covered it yet and I'm hoping that these frequent rains will ease up a bit.My backyard experiments suggest it's probably better to cover sooner rather than later. Last summer I regularly weighed and tracked several uncovered splits of various species, and they all got heavier whenever it rained and then took at least a few days to lose that moisture. The direct sun exposure you gain by having them uncovered only affects the top row of spits; the rest are shaded to the same degree regardless.
Yeah, it's like a jungle down here. With these frequent rains, I've seen days where the humidity never gets below 80%, and it's not raining. Even in a normal, fairly dry summer, if the humidity gets below 50% in the afternoon, I'm thrilled. In that drought summer a couple years ago, I would often see 100+ with humidity of 30% or less; Unheard-of here! Right now it's off-and-on showers, 71 degrees and 90% humidity; The stack isn't drying today...My father is from Kentucky and Ive never been there. But my impression is rain foresty.
I'd say definitely cover it to keep the rain off. The sun and wind are going to be the same whether its covered or not with the exception of the very top row won't get baked in the sun and you're keeping water out of the stacks by having it covered. To me it's a no brainer to cover.
I've found that if you get three years ahead, it doesn't matter whether the wood is top covered or not.
I use the carpet runners made from plastic to drape over the top of my stack. During the summer on some nice sunny days I just pull it off to help dry it. My stack is along side a fence so one side is blocked. I use racks that keep the bottom at least 4-6" off the ground and I put pavers under the feet to raise the rack another inch or two. The mostly red oak was all cuts and split by hand about 12 months ago. I use Envi 8 blocks a lot since I just do not have a lot of space to store cordwood so that should help. I also bring the days supply inside and keep it in the primary heating room. This dries the splits quite well. My hope is that the Envis and some quality wood will give me great burns this season. I found that buying cordwood on long Island is a waste of money as I have yet to get a great load of wood despite claims of sellers. Doing it myself is the only way to get the job done right.When drying wood do you think it's better to leave it uncovers until fall? That way it gets more sun and air through it. Then cover it in fall. Or is it best to cover the top of it now?
