Hi, I bought a Duraplus through the wall kit and I'm finding the installation instructions to be vague.
I installed the thimble and, if I'm understanding this correctly, the triple-wall pipe slides in from the outside and butts to the black plate which is mounted onto the inner wall. Does that sound right? I don't understand how the single wall pipe from the stove can go through the opening in the black plate and make an adequate seal to the triple wall pipe.
I was also hoping to save some money by transitioning from the triple-wall tee on the outside to double wall black pipe for the run up the side of the building. Is that possible or am I stuck buying the very expensive triple wall pipe for the entire 15 feet?
Last, none of the material I have shows a damper between the stove and the wall. Is that not required? I thought it would be.
