Anyone know why I am noticing thin shiny creosote on the inside of the ash clean out door? Inside the area that hold the pan and the pan are clean.
As a first year burner, I am burning oak which is not properly seasoned. I have been mixing it with cedar from a tree I tyook down and had been dead for several yearsOr your wood is not completely dry...
The stove is telling you to replace its ash pan door rope gasket. A simple procedure.
Yeah, if there is more shiney stuff on the door than the walls, that would point to the door gasket as the creo will build up faster on the door which has been cooled by incoming air.I agree, check the gasket and/or tighten it up with the take up bolt.
How is the CAT temp ? In order for creosote to build up on the ash drawer door it must be coming in contact with smoke. Smoke doesn't belong down there. Do you have good draft?As a first year burner, I am burning oak which is not properly seasoned. I have been mixing it with cedar from a tree I tyook down and had been dead for several years
Excellent draft...800-1200 for a cat temp. This morning is the first I had seen the creo. it is very glossy and flakes off if I touch it. I agree with the smoke not being there. Our season is about over here in georgia...eager to see what a good cleaning shows. The last load was all cedar and burned very hot, even with the air barely open. in fact, I sat up with it for 3 hours to make certain the flu didn't get to hot. It ran about 500 which was normal. When I had reloaded it in the night, I had cracked the ash pan door to increase the draft. I did this with the cat engaged and the cat temp was very low...maybe I just answered my own question...ya think?How is the CAT temp ? In order for creosote to build up on the ash drawer door it must be coming in contact with smoke. Smoke doesn't belong down there. Do you have good draft?
I'm not familiar with burning cedar, but if there is enough creo on the door that it actually flakes off, that kinda tells me that this has been going on for some time. if the door gasket were bad, and smoke is present at the ash drawer wouldn't the house fill with smoke?? This is just too wierd. I just looked at mine and all I see is a little black soot. Do you suppose liquid creo is running down from the firebox? Do you see any shiny creo inside the firebox, esp. on the front doors??Excellent draft...800-1200 for a cat temp. This morning is the first I had seen the creo. it is very glossy and flakes off if I touch it. I agree with the smoke not being there. Our season is about over here in georgia...eager to see what a good cleaning shows. The last load was all cedar and burned very hot, even with the air barely open. in fact, I sat up with it for 3 hours to make certain the flu didn't get to hot. It ran about 500 which was normal. When I had reloaded it in the night, I had cracked the ash pan door to increase the draft. I did this with the cat engaged and the cat temp was very low...maybe I just answered my own question...ya think?
I bought an infrared thermometer to measure various tempertures around the stove and I discovered the the CAT probe temperature is extremely inaccurate. I had the CAT glowing cherry red and my 1400 IR thermometer was off scale. While the probe indicated a max of 1275. When bringing a fire back up, the probe would say less than 500 when my IR said over 800 or more. The probe is NOT a good measure of CAT temperature. I use the probe only as a rough indication of the CAT's perfomance.err.....with 16 years of long winters with my DW 2460 I .....have never....got the fire going/revived with the cat damper closed AND the ash door opened a crack. My guess is that if this common practice for you that this is your creosote issue. 500 at the cat probe is the low side of normal for these stoves, mines spends most of its burning time with the cat probe temp between 800-1400 only seeing 500 on the way up or down.
