I put this in the Boiler Room, if it belongs in the Green Room feel free to move it.
My current domestic water supply is as follows:
- Submersible well pump
- Amtrol bladder tank approx 20 gal size
- Whole house 20 micron filter
- All this feeds into a 3/4" supply header
- 1/2" T to the side yard faucet
- 1/2" T to the garage faucet
- 1/2" cold supply to house
- 1/2" supply to oil burner tankless coil & anti scald valve
- 1/2" hot supply to house.
Only 2 of us here, 2 bath home, supply to dishwasher is mixed hot, we do mostly cold for laundry. The kitchen, baths & laundry area are located near each other in the rear center of the house. This is all plumbed with 1/2" which I have no plan to change. I am going to add a 1/2" outdoor faucet in the rear center of the house.
I am disconnecting the oil tankless coil, installing an 80 gal indirect & Nyletherm HPWH. The tank has 1" connections.
Is 1/2" cold supply into the tank & mix valve & 1/2" mixed supply to the house adequate? Should I upsize all that stuff to 3/4"? We typically don't have any issues with pressure surges, etc as we are generally only using one water source at any given time. The pump is set to cycle 60-70 psi.
