Ecofan for Jotul wood stove
Nokoni
145
So would you recommend me getting one of these pretty little devices?
Are they worth the cash to move air around. If so any recommendations on which model to get?
They are a cute device but do not expect it to move much air. Some use them though and think they are okay but we tried on (to satisfy the wife) and found it was totally useless.
If you want to move the air around, a much better and cheaper solution is to use a small table fan. Sit it in a hallway or doorway, run it on low speed, and blow the cool air into the stove room. This will work wonders for moving the warm air. Ten times better than trying to blow the warm air towards the cool rooms. You can also set your ceiling fan on low speed and blow the air up rather than down. I realize this sounds backwards, but it really works great.
If you want one of those little ecofans for a novelty, that is okay. Just do not buy it expecting to assist with moving air.
Hello!
A few months after our Jotul F3CB was installed this spring, I ordered an Ecofan from Amazon. I recommend the Econfan as a conversation piece ... sort of like a "science project". In fact, the Caframao Econfan web site has a link to a real "scientific" test of the effect of using an Ecofan. The University of Waterloo study reported a saving of 14% in fuel costs to maintain a comfortable temperature. (YMMV!).
Here's the link to that analysis: (broken link removed to http://www.caframo.com/shared/news/ecofanstudyadsept2010.pdf)
The fan is truly very quiet, and the speed the blades spin is determined by the stove top temperature. But then a stove top thermometer or looking at the fire are also pretty good indicators when it might be time to put in another log
It's true, the fan blows very gently and that was no surprise for me. I've attached a picture of our setup.
  • [Hearth.com] Ecofan for Jotul wood stove
@ Burntside guy, we have the exact same stove, except my pipe comes out the back. it looks like yours sits on slate? mine sits on reclaimed chalkboard slate. your setup looks great...i may be slightly biased. thanks for telling me your experience. i think the fans are very cool looking. like a little piece of sculpture. might give it a try.
backwoods savage,
first, great name. thanks for your ideas. i do use the trick with the ceiling fan and you are right that really helps. my ceiling fan needs repair at the moment. i also use the small fan, but not the way you suggested. i always blow warm air into the colder room, supposedly. as soon as i read your message i switched it and wow it does seem much warmer in here. i think i had read that trick on here years back, but never did it. now i'm thinking WHY DIDN"T I LISTEN!? hahaha. so i guess it's a weird physics thing that i don't quite get. but thanks for pointing it out to me.
well i may try the ecofan. if i didn't think they were cool looking i wouldn't go for it. but since my stove pipe comes out the back of my stove i'm thinking i can set it right in the middle of the stove top and hopefully get that baby cranking more.
Hi Nikoni,
Since you asked ;-) , here are some more pictures of the installation, the old wood shed, the beginnings of a stacks of birch from around the cabin, Albert (the dog), and so forth. The stove is set on a steel topped stove board, with the required R-value. Maybe some day a more elegant hearth pad. Your slate sounds great ... there is some slate in the Ely Mn geology so it would be a positive addition!
(broken link removed to http://picasaweb.google.com/pvoxland/NewWoodStove#)
Phil
It depends on the stove and the house setup. For our open floorplan, we can notice the difference in the far parts of the kitchen. The movement is gentle, nothing like a built in blower, but it is mildly effective. It also makes a nice temperature indicator. I can tell at a distance how hot the stove is by the fan speed.
I bought one for my VC Aspen, but the stove did not put out enough heat to get it cranking. I checked Amazon every few days and the price fluctuated to the point where I picked up the three-blade fan for under well under $100.00. My brother ended up with it and it sits on his Jotul F100 and blows air to a corner by an old, drafty bay window. It is an air mover, the bulk of heat will rise up off the stove, but some gets diverted. If you can borrow one first try it. You can use an incense stick or candle to see how far the air pushes. They don't have the velocity of an electric fan, so they will not move a lot of air, but if you want to push air near where you are sitting, it will not be distracting. They are silent too, and don't require power. A neat conversation piece, and possibly effective if it fits your situation. They are neat gauges to determine the temp of your fire. The faster the fan goes the hotter the stove. When it slows down, time to reload.
The ecofan works well for me, but I have a freestanding stove set back in an existing fireplace. The ecofan was just the thing to get a little more airflow through the hearth and back out into the room. I also do the same as BG - using the fan as an indicator of stove temp.
Has anyone had one fail. I haven't tried them since I read a lot online about them not lasting very long. I know BeGreen has used his for years, but what about other folks?
I've read that dust and careless handling can lead to their failure. It is recommended that they are stored in the off-season and cleaned of dust occasionly. I believe they can be sent back for a rebuild if needed. There is really not much to them. Basically aluminum base and fins, fan blade, peltier exchanger and a low voltage motor. Youtube has homemade versions posted.
I replace mine after 5 years, never had one fail.
Backwoods Savage said:
... found it was totally useless.
x2
You are going to have natural convection currents around the stove that are stronger than the ecofan, The table fan, put on the floor and pointed towards the stove, works along with those currents to reinforce them. I can't see my ecofan doing much but getting in the way.
Wish I knew why. I sure haven't babied it. Every year I expect it to poop out and it just keeps going. A basic table fan would have fried its sleeve bearings in the number of hours this fan has on it.
Burntside Guy said:
Hello!
Thanks. That's a lovely stove and setup,
Burntside guy....awesome setup. I think it looks great.
I appreciate everyone giving me their ideas about the fan. BeGreen, I remember your advice from years back when I got my stove and always liked reading your posts. If you use an ecofan and think it does the trick I think I will invest in one.
