I bought my Englander EP-25 new back in May and finally got all my room renovations done to the point where I could put the stove in place and fire it up last night. Since I am in the process of learning the stove (this is my first pellet stove), I am curious about the details of "how it works". I have already learned a lot by reading these forums, but I still have a lot of questions. Perhaps this info is already out there, in which case just point me in the right direction.
The "HEAT" control has 9 settings. "HEAT" is a result, not a mechanical operation. What actually changes as you go from 1 to 9? The frequency of the auger turning? The amount of revolution of the auger? Combustion air blower speed? A combination of things?
"BLOWER" seems more straight forward - is it simply the speed of the room air blower? Is this linear in terms of the volume of air moved as you go from 1-9?
Then there are the 3 buttons that confuse everyone, and yes, I know, we ignore the "Air on Temp". First of all, why are these "LOW"? Do the only work at the lower heat settings? Or is it because they are at the bottom of the control panel?
I gather that the "Low Burn Air" adjusts the speed of the combustion blower - anything else I should know about that? And "Low fuel feed" - what is that doing that "HEAT" is not?
I appreciate any clarity you can give me to read while I bask in the stove's warmth.
