Ya my door gasket started pull in out on corner not suckin air yet tho. Havnt found cheap deal on that flat door insulation yet lol
That's a great idea.. right now the air seems to come mostly from the large holes in the back of the burn plate right next to the auger. Perhaps if I plugged those 2 holes I would get a lot more air through the smaller holes. That's what seems to be happening. The small holes seem to not be able to keep up with the work load because once they get covered up a little the air just comes in the big holes next to the throat.
Wow.. I'm am idiot.. the plate must have moved while in transit to the basement and I never fixed it. I'll try that along with the Flue and the Gasket. That plate I bet is acting as A damper and covering some of the exhaust vent. I'll check it out here soon.
How do I clean the blower? Do I have to take the blower apart from the back?
Yep. Just broke the front panel glass.....
I was pulling the glass out to reset the gasket to see if I could maybe stop the leak and I dropped it. Put 1 crack right down the middle of the damn thing. 80 dollars.. already ordered a new one. It's on the way. At least iw will be ready for next winter. Lol.. oh.. and I pulled the blower. It was dirty, but didn't appear clogged. I pulled the impegment plate and felt around up there and there is a big hole on the left side that seemed open and a long slot across the middle that was completely clogged. When the new glass arrives I'll be ready to go hopefully. I'll get a pic of that plate and pot here soon.
Is it just me or does that lower auger look like its sticking out too far?
Also, the impingement plate looks like its too far to the left.
Also, you can try to slow the feed on high with the hopper plate. As for scrapping the pot, I use a 4in putty knife.
Hopper plate?
