Englander NC 30 questions
Newburnerwisconsin
485
wisconsin
Does anyone what size corner Heath pad I need for a Englander NC 30? Where can I get clearances and install information? It’s nit on the website. Also how do you remove the fiber board? Thank you.
To remove the baffle boards you just take out the front air tube and then remove the baffle boards. It’s just one little hex head screw to remove the front air tube.
Manual is here - clearances are in the manual.
It's pretty hard to navigate there on their website. You'd think it'd be on the product page for the stove.
The first clearance table in the manual is for Canada, so be sure you're looking at the right one.
Reactions: Newburnerwisconsin
Thank you!
Reactions: jetsam
Does anyone what size corner Heath pad I need for a Englander NC 30? .... Also how do you remove the fiber board? Thank you.
If the fiber board resting on the upper air tubes doesn't pull out easy and appears to be glued at the far end, you may need to run a narrow putty knife up the back-side. I've seen some RTV'd at the far end.
  • Haha
Reactions: MAD MARK
