extra long sawzall blades?
iron
641
southeast kootenays
anyone know of a sawzall blade longer than 12"? i need one that's probably closer to 14"-15" to get rid of a squeak in my stair stringers (i just need to cut some material away so it stops rubbing). in doing this, the blade will be nearly fully supported along the flimsy edge, so i don't think the extra length would cause it to bend.
not sure if you could take 2 blades and butt weld them together....
the longest one I have is a 12" diablo blade, dont think they come any longer than that. Don't see why you couldn't weld 2 together if you had too
Weld 'em up. Leave a small gap between the blades to get full penetration. Grind the weld flush and get to work.
Would it be easier to pop up the stair and then remove the material? I can just envision the blade catching, bending and scratching something you don't want scratched.
Maybe you could find a broken bandsaw blade and install a stiffener on the back edge. Grind down the end to fit into your recip saw.
You might also be able to mod a hacksaw or other type of blade to fit in your recip saw.
Reactions: jb6l6gc
