Hey guys - like the title says, I am a complete and utter rookie with a boiler. I just purchased a new house on 10/14. It is a 4700 sq ft one story with a walk out basement. It has a gas furnace on the "new" side of the house - and an electric furnace on the original side of the house. It currently has a EKO 40 boiler (I believe) that i think I am having some problems with ( more than likely user error). The prior owner has told me that in winters past the house got so hot from this boiler that they had to open windows, etc. Good problem to have I suppose...but one I've yet to experience. I have read on here what a powerful boiler it is...so I wonder where I'm going wrong?
I have a couple questions that I havent been able to find the answers to specifically on this site - - now granted I don't have a clue about this boiler OR the terminology that goes along with them yet, so I may have read the answer, but couldn't translate it!!
When he was trying to teach me how to run the boiler, one of the things he mentioned was to let it burn and heat up to 170 degrees and at that point close both chambers and the damper. If I have been running it for awhile and there are some good coals, I can get it to maintain at the 165 level for long periods of time. I'll set the dial to 169 (seems like a solid number!) and the fan will kick on. Both furnaces tend to run non-stop just trying to heat the house up to 70 degrees. When one, or both, shut off, the boiler will start to heat back up and get above the 170 mark. Once a furnace turns on, it'll drop back down to 165ish. I'm not sure if that's normal or not...and I also don't feel like it should work that hard to keep my house at the 170 mark, but I'm not sure??
Another of the issues is the fact when I wake up at 5 in the morning, it says "fuel" and the temp is down to 140 or so. In the meantime, both of my furnaces have been blowing cold air. I've been up at 2:30 checking on it in the past and its regularly at 165 and holding. I suppose I should add more wood at that time...but its hard enough to get up to check it! More wood before bed?
So, how hot do I / can I let it get prior to closing the chambers and switching on my thermostats in the house?? Is 170 a safe number? It's worked...but then it tends to not warm the house very well. When I turn the furnaces on, I obviously am blowing cold air on the coils thus decreasing the temp on the boiler. I don't have a storage tank (although he left me a 500 gallon tank that I now realize he was going to use for hot water storage)...
Also, My pressure on the gage is 15 psi. He told me not to fill it with any more water unless/until it drops below 15 psi. On another post I saw, the guy had 190 degrees at 25 psi. Should I open the gates and let a little more water in and get that psi up??
Lastly, he said that when its running right, that bottom chamber sounds like a jet engine. I saw a youtube video that kind of backed that statement up - I don't have that going on. When a big fire is buring in the upper chamber, I get some good flames down below, but nothing real impressive.
Hopefully I did a fairly decent job of explaining my dilema...but again, I don't know what I don't know
Its certainly not too warm in my house...and its not even cold outside yet. My firewood is good, although I feel like I'm using a lot. Random questions and simple I'm sure...but I'm just trying to learn how to heat my house efficiently. ANY help would be greatly appreciated
