Factory installed heat shields on Dwarf 5kw
Chiara Colella
1
Quilcine, wa
Do these factory installed heat shields on the stove reduce the amount of heat I will get? Will I still need heat shields on the walls? I'm installing in a Park Model RV. Thank you.
The heat shields will reduce radiant heat off the stove but convert it to convective heat. We have no idea if you will need heat shields on the wall just follow the manufacturers instructions.
