Finally did it!!!
lopiliberty
961
WV
I finally convinced myself to install a key damper in the pipe. To early to give results but as of right now stove is setting at 600 and pipe is at 350 with the damper in the 2 o'clock position. Without the damper stove would probably in the 700+ range. Blue secondaries dancing nicely. Before the damper it would look as if the secondary flames were coming at you 500 MPH. I'm waiting for it to get colder so I can play with the damper in different positions with different load sizes
Nice! I’ve been thinking about installing one above my englander 30.
What sort of chimney configuration do you have?
Thanks. I'll be interested to read how the key damper works out for you.
