Finally put a baffle into the Baby Bear. Took all of about 10 minutes to cut and install from a piece of 3/8" X 10" steel plate I had left over from a project.
This is a nice, easy mod to make. You can see the secondary burn that occurs under the plate. It's much easier to control the heat output from the stove now. It also definitely moved the heat output to the lower front top of stove. The back now stays waaaaayyyyy cooler which is perfect for my application. Smoke output is definitely down. Mind you, it's not EPA stove clean by any means but definitely improved.
Main benefits I like:
1) Way better heat output control. The wood burns better with less air and the plate helps shield the the top, back and rear sides of the raised portion of the stove from the coal bed. Instead the heat seems to be held down near the fuel which makes it burn cleaner.
2) Heat output changed to the front. My stove is running tight clearances and moving the heat away from the back and back sides seems to be providing better comfort. There is more radiant heat felt on the front and less heat (a lot less) coming off the back.
