Hello
Well as I redesigned the landscape of our front yard, we planted trees around the Magnolia tree and now it was time to take it down. It was small when we first moved in 20 years ago and now it is 30 feet high and 30 feet wide. So I picked up the most inexpensive electric chain saw at Sears and started hacking away! The first pic shows I am down to the last cut! I took it off as close to the ground as possible, at that point the trunk is 16 inches around and the blade is 16 inches in length! It is a one time shot so for $79 dollars for the chain saw it was cheaper to DIY !!
Then I tried removing the stump!! Drilled many holes with my electric drill and put that Home Depot stump killer in there! Stump Killer they should call it stump sauce that does not do much! 15 years or more to kill the stump? That sauce is not a killer!!
(broken link removed to http://www.homedepot.com/buy/outdoors-garden-center-lawn-plant-care-lawn-weed-control-grass-weed-killer/spectracide-1-lb-concentrate-stump-remover-129955.html)
Then I tried Burning the stump, made a nice fire all night but only the top edges of the stump was black! The hardwood stump was still real tough!!
So I called the rental place and they wanted $100 for a DIY stump grinder. I hear they are not easy?
So then I caught a Stump Grinder with a big diesel machine going by on his way to a job. So he stopped and for $25 chewed up 6 wheel barrels of chips bringing the stump way below ground level!!
Then I just raked up, add top soil, grass seed and starter fertilizer!!
Finally, I think I got a good deal after 3 years of trying to beat it down!
See pics below
See pics below
